Sail Making
A simple way to make a sail. Cut out a pattern of the sail in card. Lay on the fabric to be used with the port side facing upwards and the selvedge of the fabric on the leach of the sail Draw around the other sides of the card pattern onto the fabric. Now draw another line around the card pattern on the fabric the width of the self adhesive tape you are using outside the card pattern. Cut out on this line. Put the self adhesive tape all around the pattern on the inside of the innermost line on the fabric. Ignore the selvedge. Turn the fabric over onto the self adhesive tape, mitreing the corners. so that you have a sail strengthened all round with another layer of fabric. If this sail is for a modern racing yacht or similar, just insert eyelets in the corners or where needed. If it is for a traditional boat, barge, pilot cutter etc. The sail will need roping. Sails are traditionally roped on the port side of the sail which is why I said to lay the card pattern on the fabric port side up. I use about a 5mm cord and sew it around the outside edge of the sail except the leach to strengthen it and give it a traditional look. You can incorporate any eyes ((loops) at the corners you may want into it.
The experts will give you instructions for making sails far more complicated than this, but this is a method I have used perfectly successfully over the years.
Cheers, Nerys
Cheers, Nerys
がいいねしました RNinMunich and Colin H and
