Adhesive's
フォロワー (8)
- mturpin013Bronze
- Newby7Bronze
Adhesive's
Resin to card stock?(styrene). CA will do that job. I would probably suggest the thick version which will give you a tad bit more time for alignment.
がいいねしました RNinMunich and scout13 and
Adhesive's
Project Farm
https://m.youtube.com/channel/UC2rzsm1Qi6N1X-wuOg_p0Ng
This is to his main listing....go through his list to find your interest.
73,
CaptLarry
CaptLarry
Adhesive's
BTW......”Project Farm” also has postings on testing CA and aliphatic glues.
73,
CaptLarry
CaptLarry
Adhesive's
There is a you-tube posting called “Project Farm”....one of his post is comparing different epoxy types and brands. He is quite subjective in his test, and not sponsored by any manufacturer. Have a look....he is open to test most anything you suggest.
73,
CaptLarry
CaptLarry
Adhesive's
As everyone says, a two part epoxy for joining wood to other materials. I have been using 'Bond Together' from Poundland perfectly successfully for some time. Curiously it is only £1 per pack, but it works.
Cheers, Nerys
Cheers, Nerys
がいいねしました scout13 and Madwelshman and
Adhesive's
All as have been previously posted. I would add G-Flex epoxy for dissimilar materials, especially those that will not be effected by some heat generated during the cure. -Flex does not sag as regular epoxies do.
An added comment, do not use CA or super glue for adhering windows to frames. It will fog clear styrenes.
White glue( PVA) for wood to wood, slow but old school.
Lastly, as mentioned, try to understand the stresses that your joint will be under and plan your glue to deal with it accordingly.
Adhesive's
Hi there
Z-Poxy 30min 8oz Epoxy Resin PT39 for GRP to Wood
Deluxe Materials Aliphatic Resin - 500g (Economy) S-SE10 for wood to wood
Zap Formula 560 Canopy Glue PT56 for windows
Deluxe Materials Plastic Magic 40ml S-SE54A for styrene
That's what I use hope that helps
Adhesive's
Hi Carpcruncher,
I think you have opened the floodgates now. LOL!!
You will get some great advice regarding adhesives.
So i will add to your request, I use two part epoxy for wood to fibreglass (Araldite).
Good luck with your Tug Portgarth.
Will you be doing a build log ?
Adhesive's
You will get a lot of good answers to your glue needs.
I use Gorilla wood glue mostly.
"Goop" is another I use when cured remains flexible joins many materials together.
Two part epoxies (5 min) may be used to join parts.The epoxy heats when curing and may distort items in curing.
I believe La Pages has a canopy glue that dries clear for windows .
Hope this helps some.
Rick
Rick
Adhesive's
Hi All can someone please help me with my question
I shall be starting to build my model tug which is mmm Portgarth
the question is this is my first big build and I am not sure what glues to use such as wood to fiberglass hull and wood to wood also when I put the windows in what material should i use and glue for fitting them any help please
Tenchman
がいいねしました
読み込み中…
