Mounting a Mtronis Viper speed controller
Many thanks, Geoff, it makes perfect sense for once the easy option is the correct one! Funny how the 'engine room' becomes crowded with the wires, I am looking forward to having all the electrics in place.
I hope you are keeping safe, best wishes Treve
がいいねしました Martin555
Treve, I always use self adhesive Velcro, gives some flexibility to the installation and removal for access to other parts in the hull easy, or even to move to share it with another model. Make sure that the esc has room to breathe as the fins and metal base are the heat sink for the electronics, Also be aware the esc's get hotter at slow speeds than they do at full speed.
Geoff.
Geoff.
Geoff L.
I normally use Velcro tape. I the glue isn't strong enough a bit of medium Cyano helps, Remember it needs air around it so not to close to the motor, also helps to keep it away from the receiver and aerial
Ian
Ian
がいいねしました Martin555
Hi Treve,
I have fixed these speed controllers down in two different ways.
One, i have used double sided tape and it never got hot enough to make it come unstuck.
Two i have made a tight fitting wood frame around it.
Glued the frame to the base board then pushed the speed controller in to the frame.
がいいねしました Seanympth
Hi I am hoping for some advice on how to secure the speed controller to the boat, is there a bracket to fit the ridges on the side of it, if so please advise me where I can buy one. Its a nice construction but has no provision that I can see for securing it to the 'engine room' bulkhead.
Many thanks
Treve
Many thanks
Treve
がいいねしました Ianh
がいいねしました
読み込み中…
