The Duchess
Hi woodie, l
A little diagram may help!
please note a car fuse holder will do,
The speed 600 will pull 85 Amperes when stalled (stops spinning due to weed or string) max efficiency is 12A so a 20 Amp fuse would be a reasonable choice.
Specification
Nominal voltage 7.2 V
Operating voltage range 3.6 … 8.4 V
No-load rpm 18200 min–1
No-load current drain 2 A
Current drain at max. efficiency 12 A
Current drain when stalled 85 A
Max. efficiency without gearbox 69 %
Length of case, excl. shaft 57 mm
Diameter 35.8 mm
Free shaft length 8.7 mm
Shaft diameter 3.17 mm
Weight 195 g
Hope this helps
Regards Roy
Specification
Diameter 35.8 mm
Weight 195 g
Hope this helps
Regards Roy
Regards Roy
がいいねしました Martin555 and RNinMunich
