Clyde Puffer Build.
フォロワー (6)
- mturpin013Bronze
- CashrcGold
- Newby7Bronze
Clyde Puffer Build.
Hi Gary, That's a bit harsh on Doug who puts so much into this site with lots of useful information and keen sense of humour .
Cheers Marky
Cheers Marky
がいいねしました Martin555 and RNinMunich
Clyde Puffer Build.
" and then Doug stuck his neb in as he can't help himself. "
Gary? Gary who?
Gary? Gary who?
Clyde Puffer Build.
Best Way Colin,
Same as my Myford I didn't intend to part with it but mine was stolen.
Quality machines are hard to find. Unless you want to buy something like a 7 x 10 and spend quite a bit on it to get to a Unimat or Myford level😀
Clyde Puffer Build.
Hi Gary,
As Colin has said Doug (RNinMunich) dose a lot of research for the members of this site saving them time and effort, also the knowledge he freely passes on is also very valuable.
Like other members myself included we try to be as helpful as possible.
Each of us has different strengths and specialties and are able to help other members in those particular areas.
It is because of the good will of the members that has made this site as fantastic as it is.
I like many others hope to be as helpful as possible and to encourage new members in to this very interesting Hobby.
Clyde Puffer Build.
Take it with you Colin just to upset him LOL!!
がいいねしました Colin H and RNinMunich
Clyde Puffer Build.
Good morning Ian, I inherited the unimat from my father, and already my son is trying to get me to give it to him, but I told him that he will have to wait till I'm in me box in the ground.
がいいねしました RNinMunich and Ianh
Clyde Puffer Build.
Like your solution to the propshaft problem, that’s slick!
がいいねしました Martin555 and stevedownunder
Clyde Puffer Build.
The shafts' bearing's sprockets and chains would be ideal for a paddle steamer, do you have access to a lathe to make bearing housings, small neat ones? As the Motionco bearing mounts are a bit over the top size-wise.
がいいねしました Martin555 and stevedownunder and
Clyde Puffer Build.
Gary, thanks for the info, and yes doug often researches sites and passes on the links for us to use. I don't have a problem with it as it saves me a lot of time.
I do like what you have done so far and am avidly following your progress.
The shaft and bearing housings are in my thinking for driving a paddle steamer, but electric not steam sadly.
がいいねしました mturpin013 and Martin555 and
Clyde Puffer Build.
Here's one I built earlier, note the ball-raced main bearings.
Clyde Puffer Build.
Good to hear you are contemplating a STEAM project in the near future, get yourself a TVR1A BB engine in kit form and build it yourself, a 1/2" bore twin-cylinder slide valve, a very efficient engine which only requires 20 - 30 PSI to run flat out. When you have built it and sorted your valve timing, you'll know everything there is to know about slide valves. A suitable boiler would be a 3 1/2" diameter x 6" length, you can buy a kit of parts and save an absolute fortune, I have seen your silver-soldering. Regards, Gary.
Clyde Puffer Build.
がいいねしました stevedownunder and Colin H and
Clyde Puffer Build.
Great job Gary and a very clever solution to a problem many will now benefit from.
I have to say I got side tracked on my steam project because of a sort of commission build and secondly by the dreaded virus, however be assured it is next on the list.
がいいねしました stevedownunder and Martin555
Clyde Puffer Build.
Hi Colin, and yes of course you can have the name of the supplier of the chains, sprockets, shafts and bearings. It is motionco and they have a lot of interesting gear worth a good coat of looking at, a chain tensioner is not required as just take a link out or add a link when required. The chain is plastic as per the sprockets, but is very very strong, incredibly strong actually. Regards, Gary.
がいいねしました stevedownunder and Martin555 and
Clyde Puffer Build.
with regard to oil and oiling a steam engine, the steam enters the engine via the lubricator which carries steam oil in the vapour to lubricate the engine internals and moving parts, this is required as model steam engines use an O ring on the pistons, so oil in the cylinder bore is essential to prevent the O rings being shredded. a fine car engine oil is required for crankshaft main and big-end bearings, and all moving joints as per Hackworth linkages and eccentrics etc. The shaft bearings are ball raced sealed for life and the sprockets and chains are of a very hard PLASTIC, although I do admit they look very real so no oil required there.
Clyde Puffer Build.
Can you share the pervayer of the shafts and bearings etc.with us lowly modellers.
I love your solution, and do you have any chain tension adjustment.
Clyde Puffer Build.
Thanks Rick, I appreciate that comment and that's what I had in mind to get the prop shaft to go around the boiler. Then I managed to find a company that made the shafts of either 3 or 4mm diameter plus the bearings and bearing housings, sprockets and chain, basically, everything I needed all from one source at a very reasonable price into the bargain. I have kept the gear ratios at 1 to 1, which could be either geared up or down depending on how it performs on the water. Regards,GLC. (Actually, having solved that problem I seem to have come to a grinding halt on the progress front.) must try harder.
Clyde Puffer Build.
GLC All I can say is wow.Your skill sets and thinking out side the box.Wonderful.
Rick
Rick
Clyde Puffer Build.
Really clever solution , will follow the build with great interest .
Cheers Marky👍
Cheers Marky👍
Clyde Puffer Build.
A great start Gary.
For the benefit of the new guys when an engine like this is used do you have to oil every thing including the chains every time you go to use your boat. ?
がいいねしました Colin H and stevedownunder
Clyde Puffer Build.
I don't know either, but this does happen occasionally, photos seem to just materialise!
Nerys
[Edit] Photos removed martin555.
Nerys
Clyde Puffer Build.
As that prop shaft solution is a little confusing hopefully these photos will help.
がいいねしました mturpin013 and jbkiwi and
Clyde Puffer Build.
That's nice, really appeals to me, a steam driven puffer Will follow this build with interest.
Nerys
Nerys
Clyde Puffer Build.
My latest building venture is a Clyde Puffer from Mountfleet, which I have made a start on and have managed to sort the somewhat complex problem of running the prop shaft drive around the boiler which is at the back end, with the engine positioned in the middle. As hopefully explained in the attached photographs.
がいいねしました
読み込み中…
