diesel help
HI Lyle, thanks. I partially stripped the motor, cleaned the carb side and barrel. There wasn't a lot wrong, a bit of sticky old oil and carbon but nothing nasty. The only thing was the alignment of the throttle air hole and the servo arm, what I assumed to be fully open was about half shut. Anyway I set it up on the bench again and after a bit of spinning she went fine- a bit too fine really as the engine mounts shook loose 😯 do before I could do any setting up but a good 30 seconds of strong running and throwing unburnt fuel out the exhausts before I stopped it! So now I have set up a water supply and need to sort some M3.5 nylocs (anybody know where to get those?) and I can get it set up a bit. Oh yeah, sorting a silencer for it as well, I guess it is a bit noisy as it stands! Still not sure of the model though, it is a 2.46 ED but the number is 66/5 so I can't work out what it is from the guides I found so far, if anyone has any info on that I would like to know.
Cheers again,
Glenn.
Cheers again,
Glenn.
