NewBe Help Needed - Noisy Motor Arrangement
Neil
Another tip. While aligning the prop shaft and motor I have found it useful to use a couple of lumps of blu tack. I used on both but on the tube, place a lump in the angle created by the tube emerging from the hull and again inside where the tube enters the hull. then press firmly into the blu tac too hold in the desired position and apply some glue. Alternatively apply glue before inserting tube and let the blu tac hold in position. Then make final adjustments to motor alignment Ie using shims before fixing.
がいいねしました doghouse
