COUPLINGS
Hi Roger, no worries using the idea, that's why I put it up, as many people have had the same problems I've had with the Chinese stuff,(with planes and boats) As long as your tubing is a good tight push fit it should hang on ok, but if you can fit those really small zip ties, just place the zip locks at 180 deg to each other and they should be fine. You can also experiment with the ties for any fine balance required, -leave them only just tight enough to be able to move them, and move them round alternately 30deg at a time to see if there is an improvement (if it's not way out). If you can get 2 small ties on each end 180deg apart, you have more balancing opportunities. I've balanced 46 diam outrunners like this. You also need to check the shafts, - rolling them on a flat surface with a light behind is a good way to spot any bowing,- doesn't take a lot to cause vibration (gets worse the higher the revs).
You might need to manipulate the silicone a bit on the splines if it's been in a tight coil, as it can cause a small vibration initially,- usually sorts itself out though. You could fill the inside gap up with silicone (or a piece of smaller tubing) which might stop it twisting on hard starts if you have a powerful motor, but it's probably not necessary if you use the thick tube . Cheap as chips to experiment with, and once you have the size, you can cut a bunch of spares for the tool box. Hurts nothing if it breaks. If you hear it squeal just back the throttle off, it will be the silicone slipping (automatic throttle control 😁) Good luck with the experiment.
