Adhesives
Any glue works best with a sanded surface, it give it something to grip on to. So yes, you are right in thinking about sanding the glue line on your boat.
Any 2 part adhesive is only as good as the person getting the quantities correct, sp perhaps the previous builder did not get it quite right, as I too have bought a boat and had to replace a few areas of resin bond.
Any house type adhesive should be tested on a piece of space material first, as you quite rightly say, it could damage the hull. I would also read the label too as the majority of glues may be "waterproof" but they will not cope with the long term Immersions given to a model boat and they too will eventually fail.
I do prefer to use Stabilit as there is little chance of getting the mixing quantities wrong with their measuring system, but make sure you mix it well to get all the powder mixed in.
best of luck and dont forget to post some pictures of your rebuild if you wish as no doubts a lot of followers of this site would like to see it to completion.
Best wishes.
Gregg
Gregg
