Flotation.
開始者 Martin555
3 返信ies 9 いいねs 最終活動: 6年前
Flotation.
Some of my models use polystyrene blocks fitted in where possible and I've also used filler foam in a can to fill sealed compartments.
On one occasion I used bubble wrap stuffed into various spaces.
がいいねしました Martin555
Flotation.
I've fitted bulkheads at both ends on some boats and filled them with odd bits of polystyrene packing materials to provide buoyancy in case of accidents. I did this after the first model I made, a small fishing boat, was swamped on two occasions, and Alice having to go wading in the lake. She has a pair of waders now.
Cheers, Nerys
がいいねしました MouldBuilder and Martin555 and
Flotation.
I have used it on some model yachts. I use foam filler in a can from your local DIY.
Made by Various companies but I use Fischer and Henkel😊😊
がいいねしました Colin H and Martin555
Flotation.
Hi Guys,
We all mention things like battery's, motors ballast.
But don't seem to mention anything about adding foam or other forms of flotation.
In a model Submarine this is important, but not so much in a model boat.
For the benefit of new guys to the hobby it is put in to a model boat just incase you suddenly end up with a lot of water getting into your boat.
Hopefully you can get enough flotation in it so that it dose not actually sink and you will be able to retrieve it.
Do any members have some hints or methods on this subject that will help other members and new guys.
がいいねしました MouldBuilder and Ianh and
