Model vertical boiler
開始者 Newby7
7 返信ies 14 いいねs 最終活動: 6年前
#7 1
I will be using a steam engine as I have the Graham TVA engine I built.I was just trying to cut costs down with different thoughts and these replies are very helpful thank you all.
Rick
がいいねしました Scratchbuilder and Martin555
I do apologise Ian, i should be more careful and read these threads properly.
がいいねしました ianed57
Hi Martin,
It was Rick who wanted to do this, I only looked at it at one stage. I think the article that Tony has linked to would be very helpful. I wasn't sure if Rick wanted to use an actual steam engine and power it electrically or hide an electric motor in a casing such as might be used over a steam engine in an open launch. All of it would be possible. Given that most working steam boilers are vastly over scale it might be a good opportunity to get things more in proportion.
Rick, another way to go might be to just build an electric launch. Many of them were just as attractive as steam launches. I turned my Wild Rose from steam to electric and hid the gubbins with a mahogany box. It also means that a nice striped canopy won't get covered in oily gunge, and nor will the rest of the boat!
Tony, I noticed there was a model outboard in that MB special- looked very smart.
Have fun all,
Ian
がいいねしました Martin555 and Colin H
Back in 2016, Model Boats magazine's Winter Special edition featured an item about building Vic Smeed's River Queen open steam launch design, using a dummy horizontal boiler and mock steam engine. Incorporated into the model was a smoke/steam generator. The clinker hull was GRP.
https://pocketmags.com/model-boats-magazine/winter-special-16
がいいねしました ianed57 and Martin555
I had considered using a mist unit in one of my launches as a sort of ' faux' boiler as they work well. I could only find a horizontal boiler shaped unit from Model Boat Bits here in the UK. They cost around £50 which isn't cheap, but certainly cheaper than a boiler. I did find a vertical example but they don't seem to be produced anymore.
If you weren't bothered about steam coming out of it, it should be easy enough to mock up a boiler out of a tin or similar with mahogany lagging - or make up a cylinder from styrene sheet.
Many steam launches had the engine covered with a wooden casing, ie the Windermere launches, and that would also be a way of disguising fact that you didn't have a real steam engine, although reading your post again, it sounds as though you intend to use a steam engine turned by an electric motor.
Sounds fun.
Ian
がいいねしました Martin555
I 'm in the process of putting together a plan to build an open launch but had an idea to use an electric motor to run the steam engine and cover the motor with model of a boiler .With that it would cut the costs of buying a working boiler and gas tank.Any one know of a model steam boiler kit .
Rick
