Lockdown project
開始者 crowie100
9 返信ies 18 いいねs 最終活動: 7年前
Lockdown project
Scratch built. Designed on AutoCadLt
The bearing is from an old golf cart.
がいいねしました MouldBuilder and Martin555
Lockdown project
The windmills are they kits or scratch built.Were there plans for them if so where did you find. The reason I ask is I have a Stuart 10 horizontal engine I'd like to build and run a windmill at some of our shows .
Rick
Lockdown project
Yes, waiting to see our projects on the water will be very nice. Since last fall there has been three boat builds come across my work bench.
Tried to post photos in order of text, but alas, the deck got shuffled.
Starting with Miss Katherine, a small tug seen at a boat yard in Mahone Bay, Nova Scotia, Canada.
Next, a Folksboat seen in a boatyard along the shore of Lake Geneva, Geneva, Switzerland.
Most recently the 1/35 Italeri Vosper MTB 77 RC conversion which is nearly complete.
Along the way in between the three boats there were three “weather vane” whirly gig style projects. Two were replica Dutch windmills, and the other an airplane for my grandsons.
Plus two plastic model cars...
がいいねしました redpmg and MouldBuilder and
Lockdown project
Nice job. I think testing our boats is something we all look to do .See them on the water and make sure every thing is tip top .
Rick
がいいねしました Martin555
Lockdown project
Yes I think mine was certainly based on the swift boat. I think the ones in Brazil are a Swedish design with water jets. It's not a replica build in any way 👍
がいいねしました redpmg and Martin555
Lockdown project
Nice boat - very well made for a scratch build - looks a bit similar to the US PCF "Swift" boat used in Vietnam.
がいいねしました Double Rum and Martin555 and
Lockdown project
Nice work.
well done.
Lockdown project
Nice little boat.😀
がいいねしました Martin555
Lockdown project
I though you might like to see my latest build. It's a semi scratch built fast river patrol boat. I read that the Brazilian military use this kind of boat for anti pirate and drug smuggling patrol on the Amazon and other rivers. I changed the flat bottom hull to a V and put in a 1400kv brushless. The cabin and upper deck was changed to match pictures I had found and a few other changes. I've installed revolving radar, 50cal sound emitter, search light and pursuit lights. I had to put in quite a lot of ballast to get her to sit right. I won't know if sails right until the lake opens again, but I'm quite pleased with the results.
がいいねしました redpmg and Graham93 and
