RAF Range Safety launch help.
So easy , it took me months years to come to grips with the model . It was the SAME issue as I tried to work out to build the bedstead aerial . it was one of those 45 am dreams of model boats and I just made a BALSA plug and bent wire around it and then soft fuse wired the top prongs together and the bottom prongs together. I soldered the whole top thicket of wire twigs and the bottom twigs then with my dremel cutting disc cut each twiggy mess away and then shaped the top and bottom similarly and had a wire well shaped BASKET skinny and vertical and SCALE. I picked out the hard balsa plug and soldered the mast and mounting apparatus etc . Well the rest of the model was a dream with a super tiger 21/23 for years and now an OS 25 FSR and she is probably 20 years young now . Regards Lyle. I will try for pics
