Air Sea Rescue Launch 123
If they are the same as Doug posted a little while ago, they only show total volts for NiMh (only a pos and neg plug). The only way you could get individual cell voltage would be to have the cells wired similar to LiPos with check/balance wires from appropriate points, but I don't know if there are any checkers readily available. You could re wire a pack to a multi plug so you could check individual cells with a multi meter perhaps. Doug will probably have a better idea being the tech man. The problem with NiMh cells is there can be large numbers in a 'pack' (as against LiPos which have purpose designed chargers and checkers with JST-XH leads for 1-10 cells) and if there is a dud cell in the middle you won't know till the battery keeps dropping its' charge quickly when not being used.
