Fairmile c class maiden voyage
Exactamente John, 👍
You beat me to it!
I'm experimenting with the P94 to improve the 'cornering' of my long thin, 10:1 LoA to Beam ratio, destroyer with twin 540s, and will use one (or the Brushless P40 version) in my triple screw PTB.
Beauty of the hardware mixer is that you can switch off all the aircraft / heli mixer functions at the TX and just use one stick for both rudder and throttle! 'One thumb control'.
Much easier and cheaper than buying a dedicated TX etc. 😉
OK; if you want independent control of centre / outer screws you need an extra ESC (disconnect the 3rd output of P94) and a second throttle stick. But you can still use the P94 to spin the boat 👍
NiMH vs SLA? 👍 Going LiPo would improve the power/weight ratio even further 😊
You beat me to it!
がいいねしました Rookysailor
