LED Lighting tip
開始者 Martin555
9 返信ies 23 いいねs 最終活動: 8年前
LED Lighting tip
Hi Martin,
"I suppose I should get up to date and do things properly."
Judging by your results with Cottesmore you can't get much more 'proper' than that!!👍
Shame that I don't like yoghurt 😝🤔
Doug
がいいねしました Martin555
LED Lighting tip
Just like 'real life' conversations Red 😉
An old 13A plug (useless over here!) saved my bacon last year when I lost a 5BA nut from my Taycol Target while renovating it. Try buying brass BA nuts in Germany🤔
After much scratching about I discovered that the wire clamp nuts in the plug are a perfect fit, even better they don't need a spanner 😊
Glad to see that we 'boaters' are doing our bit for the environment 👍
がいいねしました rolfman2000 and Martin555
LED Lighting tip
Join the club - have all sorts of gears from clocks & printers etc , motors from hairdryers and old printers (new ones tend to have steppers), both round and square brass old electric plug prongs (very useful), 1000 odd 1/4" long brass rivets from a waste bin, wood from fruit boxes including some nice ply, planking strips cut from discarded pallets , some short mahogany planks from a wrecked Air Sea Rescue boat at Cape Point (the vandals at Cape Parks burnt the wreck which could have been salvaged by a friend who collects full size boats)), and a lot of roller type micro switches also from the bin.
Isn't it funny the way threads wander off the original topic
がいいねしました DodgyGeezer and RNinMunich and
LED Lighting tip
Hi Martin,
There's a saying over here amongst ship model builders, which translated means
"Ship modellers will collect and save anything that won't start to stink after a few days!"😉
I do the same as you with old video recorders, PCs, dead garden solar lamps etc etc.
Great sources for motors, LEDs, power supplies, fans, connectors, ribbon cables, cogs n pulleys .....
I also browse around the flea markets here; great sources for odd bits n pieces.
Have found boxes of assorted cog wheels and pulleys, once even a whole tray of miniature 5V relays. Which I used for a home made controllable switchboard in my destroyer. See pics!
Carry on recycling👍 Cheers, Doug
がいいねしました Martin555
LED Lighting tip
Hi Guys,
Thank you for the LED calculators it is much appreciated.
Being an old guy and doing things on a zero budget is a bit of a challenge,I tend to use whatever I can get my hands on.
I selvage old broken electrical stuff for the parts to use on my models, and recycle plastic food containers for usable plastic.
I tend to look at all sort of things and think to myself what can I use that for.
It is surprising what you can make from junk!
Thanks again Guys.
Martin.
がいいねしました redpmg and RNinMunich
LED Lighting tip
Hi All,
I would recommend this one
http://ledcalculator.net/
Gives more useful straightforward info, incl. wiring and cct diagrams and useful links for the electronics novice, and without all the ballast of the nonsense and abusive comments!
Happy LEDing 😉
がいいねしました Rookysailor and Martin555
LED Lighting tip
there are any number of 'led resistor calculators' on the web. Google one, then fill in your voltage,etc and it will tell you what resistor you need... I'll start you with one...
がいいねしました Martin555 and redpmg and
LED Lighting tip
Hi Hillro,
Well I am not an electronics expert and it was just an experiment.
I had a few LED's of different colours knocking around so I just linked them up in parallel.
Unfortunately I have a habit of doing things just to see what happens.
I used one red and one green LED and a variable resistor and it worked fine.
You are supposed to use ohms law to work out the required resistance but I just try it if it works great of not try something else.
If I only had the exact amount of LED's then I would do it properly.
I hope this helps.
がいいねしました doghouse
LED Lighting tip
Hi Martin.
The idea seems to reduce problems with supplies for LEDs
However ,how have you handled the differences in voltages required for different colours.
Robert
がいいねしました doghouse and Martin555 and
LED Lighting tip
Hi Guys,
I have a little tip for powering some LED lighting.
When you use the BEC from the ESC it will free up the socket that the battery would of used.
So if you use a receiver connector and connect some LED's to the red and black pins
You have a low voltage power supply.
I have used this to power the navigation lights on several models,also it indicates when the boat is switched on.
がいいねしました rolfman2000 and Donnieboy and
