H.A.Kits will be attending the Model show in Coppell, Lancashire on Saturday 23rd march. This will be our first event as a trader, our latest products go on sale for the first time plus all are models are on display. So come along and see our products, maybe pick up some bargains and freebies!
Lazer cut Kits
Hello modellers, just a bit of an update. I have been busy designing 3 more model kits, A pilot Launch (540mm), River cruiser (500mm) and a slipper launch, the latter will be available in 2 sizes 460mm & 700mm. I hope these will be available by early March.
Lazer cut Kits
There would be no need to remove them if you simply follow the correct procedure and ask permission from the rights holder. I have found that Amerang are quite happy to allow people to make use of their old plans.
They were happy for me to reverse engineer the kits, create line drawings and place them on my web site for the use of younger modellers. Maybe you came across them there? if you had asked, I could have given you a .DXF file and saved you some work......
Lazer cut Kits
Hello, I have just started advertising them on ebay. if you are interested you can contact me via enquiries@hakits.co.uk. Thanks.
Lazer cut Kits
Where are you advertising them all for sale please. They look quite good.
BOATSHED
Lazer cut Kits
Hello, As i said the kits are based on models i built in my youth. Now i am retired i enjoy drawing in cad and the challenge of turning my drawings into models, I thought other people might wish to build my models especially younger builders and so i sell the kits at cost. I take on board your helpful comment and will remove them from my advertising.
がいいねしました Sifi70
Lazer cut Kits
The first two look like the Mermaid and the Cresta from the old Keil Kraft range. You should be aware that Amerang still hold the rights for those....
Lazer cut Kits
Hello fellow modellers, I thought you might be interested in my range of small model boat kits which i have been selling on a well known auction site. I have started with 6 basic liteply kits based on models i built in my youth. They are all computer drawn and laser cut making them accurate and easy to construct. When i designed these kits it was with the thought that maybe they could be built be younger models with help from a more experienced assistant, therefore they are at what i could call pocket money prices ranging from £29-£39 each. I would be glad to hear fellow modellers thoughts, Thanks.
がいいねしました
読み込み中…
