Yep!👍
https://www.componentshop.co.uk/p95-indicator-fuse-boards-single.html
Spec attached as pdf.
Strictly speaking the LED simply indicates the polarity of the voltage applied to it. Which way the motor turns depends on how you wired it.
But it does help with setting up the wiring and response to TX throttle stick.😉
Easy enough to make though, as I did for my Sea Scout.
See pic of 'Engine Room'.
Or the Taycol field motor converter boards I've made for Martin and Colin. Two fuses are fitted; one for the field coil, one for the armature.
Last two pics. Resettable fuses (contact breakers) are also available to fit these holders. Cheers, Doug 😎
