Brushless motor(s)
開始者 Little-Charlie
8 返信ies 6 いいねs 0 フォロワー 最終活動: 8年前
Brushless motor(s)
Thanks, probably explains why the original motor is out of stock with no estimated replenishment date.
Will update my notes to the 3639 750 kV
Rowen
Brushless motor(s)
Hi RHBaker
I had the motor ,so I used it.
The sister motor is a 3639-750kv 600Watts 8325 rpm on 3S.
The 3639-1100kv 800Watts 12210 rpm on 3S.
Next up the 3648-1450kv 1600Watts 16095 rpm on 3S.
All are straight bolt replacement, but, the 3648 requires a 100Amp ESC.
The 3639 750kv would be the better motor for the boat to get scale speed.
Canabus
がいいねしました rcmodelboats
Brushless motor(s)
Well Canabus, certainly fast! Very envious of seeing open water too.
If was not obsessed with building to scale, looks like your power train combination would be ideal.
Once the water is Canada regains liquid form will be returning to my Brave B. Am confident it will now be much better, although potentially still overpowered.
Have various methods available for controlling the performance in mind now. However, if nothing really works could, with some minor modifications fit a powertrain rather like yours.
More food for though!
Brushless motor(s)
Charlie,
Good question.
I have a number of brushless motors and esc' from my model airplane days..... I model slow boats like tugs and just assumed that they would be too fast for these boats, but I don't know if this is true or not....
Maybe someone out there knows?
Joe
Brushless motor(s)
Hi Charlie
I have tested my 37" Perkasa with a brushless 3639-1100kv motor from Hobbyking, a 60A ESC, 3S 5800MAH Lipo battery and 37mm 3 blade CNC prop.
It's dam fast !!!!
Canabus
がいいねしました Little-Charlie and BOATSHED and
Brushless motor(s)
Thanks Rowan for your second message I do appreciate the offer and I am sure you will be hearing from me in the future
Little Charlie
がいいねしました doghouse
Brushless motor(s)
Thank you Rowan it has been very useful, will eventually post how I get on, not as simple as one thinks, never mind onwards and upwards as they say................once again thank you for your response
Little Charlie
Brushless motor(s)
Charlie. Have recently been through this challenge with my 37” Brave Borderer. My blog on this site may not give all the answers, but it might save you making the mistakes I did
Rowen
がいいねしました RNinMunich
Brushless motor(s)
Hi, I have recently purchased a Precedent KD Perkasa kit 37" and would like to power it with a brushless motor, but being an Old F**t I know nothing at all about Brushless Motors or their relevant speed controllers or battery power. So I would like your input on what exactly I need, obviously I would like the model to have a fair turn of speed. Thanking you in anticipation of your much needed assistance. Little Charlie
