Taycol supermarine dimensions.
開始者 Colin H
4 返信ies 3 いいねs 0 フォロワー 最終活動: 8年前
He He! Me 2, just ordered new specs today!😉
Slotted base is good. Variation in length due to my mods shouldn't be more than a few mm.
がいいねしました cumbrae
Sorry Doug, must need new specs, the mounting holes will be on a slotted base plate to allow for final adjustment for and aft. So any dimensions that change should be okay.
がいいねしました RNinMunich
Hi Colin, I measured on your motor and it's 1&1/4 inches as specified.
(Did mention that in my post!)
The length between mounting hole centres may vary slightly from original spec, depending on the new bearing bushes I'm fitting.
Can't measure that until I have it reassembled.
I'm nearly back up to speed now so will start the reassembly shortly.
がいいねしました cumbrae
The picture and details Doug posted were useful but the important dimension for the centre line of the shaft above mounting base line isn't quite clear enough to read. Any one got a clearer copy of the details list they could post on here would be appreciated.
