Multi tool Kits
開始者 onetenor
4 返信ies 6 いいねs 0 フォロワー 最終活動: 8年前
Multi tool Kits
Just as I thought Thanks. I agree re Hilda tools too. Excellent product although there a various ones. Go for best you can afford.👍
Multi tool Kits
I have several sets like that. Bought over the years from this shop and that. Lately mainly Lidl and Aldi. They are all the same quality and work perfectly. I am a professional modelmaker, so I've put these things through the mill over time and never had any complaints. I tend to use my Proxxon drill, which is always flat out as the electronic speed control packed up so I wired it straight through. That might explain why the drum sanders struggle a bit sometimes. I now use them on a drill with a lower speed capability and they're doing better. Grinders never last long, so it's as well to have as many as you can gather. I think the fact is, these tools are only likely to be made by one or two companies, so all are as good as each other. And they come in such NICE boxes!
がいいねしました Brianaro and Donnieboy and
Multi tool Kits
Hi Brianaro
I have a HiLDA from Banggood.
I third the price and all the fittings fit the Dremel.
The Hilda looks the same as the Dremel with a different badge.
The Hilda is powerful and with a speed control as well.
The Hilda kit comes will a flex lead as well.
I am very happy with mine.
Canabus
がいいねしました NPJ and suntugs
Multi tool Kits
Difficult to know, unless you buy Dremel most of these sort of tools seem to be of similar quality. I’ve found that some (regardless of cost) ware out fairly quickly. This set isn’t a lot of money so not much to loose if not up to much, but I think you will get your money’s worth out of most if not all of the items
がいいねしました suntugs
