Which battery?
開始者 Brianaro
2 返信ies 2 いいねs 0 フォロワー 最終活動: 8年前
Which battery?
Thank you for that, it has helped a lot. I have liPo in another fast boat and do worry about the safety, I keep and charge it in a fire proof bag. I will need weight at the front of the boat so Lead Acid will probably assist. The build is good fun. Thanks again
がいいねしました petercbrown
Which battery?
I tend to use LiPo's but they can be temperamental and need the correct charger. They are smaller and lighter than NiMH and give you a much greater output. NiMH are similar in size to LiPo but are heavier and will not have the same sort of power available. Lead acid are the easiest to use in terms of charging but are much heavier and larger then the other 2 types but tend to be cheaper. Lead acid are a good option if you need the ballast or are not limited on physical size. Cost is also a consideration a good quality charger can be an hefty investment but will serve you well and if you buy the correct type will charge/discharge any battery type that you have. I have heard horror stories about LiPo's bursting into flames, which my son did with his RC car. this was down to him not understanding this type of battery. I have not had good results in terms of endurance with NiMh but Lipo's if correctly selected will last much longer, a word of warning here though, they will stop working suddenly with no indication like running slow etc so if using LiPo's you will, need an alarm on each battery. Lead acid is much easier to in terms of Voltage either 6 or 12v with real problems when connecting them in series or parallel for use or charging, a little harder with the other two types but not impossible. This has probably confused you even more but I am sure you will come the correct battery. I have to confess I have an interest in this build as I intend it to be my next project👍
がいいねしました Donnieboy
Which battery?
I have a 1:16 Taymar lifeboat with twin Graupner 600 motors. Which batteries, Lead Acid or NiMH. Can anyone help please, what is the benefit of one over the other?
