Beginner Restoration
Yes if you are prepared to spend the time involved. You need to remove all the paint before you start then cover with some light glass cloth. Resin over and scrape most resin away with a piece of plastic (credit card size) so that you do not add too much weight to the hull. Finish with plastic padding to produce a smooth hull. if you have a local supplier (try your local business park) you can use epoxy in place of resin. This can be sanded and a final coat will produce a really superb finish.
I would have suggested this earlier but it is a lot of work and not a quick process. Others on the site have used similar methods and you should be able to find more details in the forums. Perhaps someone who has posted details will point you to the right post.
Good luck
Good luck
