Sea Queen prop shaft
Thanks for the advice M Turpin (don't know any more than that), I am with you on that, I worked out that I actually needed about 500 mm length. So will thread the one end (actually less thread than the one supplied) then fit - measure - measure then cut.
Sidley70 - I think I would have been tempted to remove the old shaft (the outer tube) and fit a new one. I suppose it depends on how well the original is fitted. Having removed one many years ago from a boat. My method was to have a reasonable size piece of steel drill and tap to the size of the old prop shaft, fit to shaft - this holds the piece at the end of the shaft - the basically give it a bash with a hammer - now in my case it came loose and then by swapping round and bashing from the inside, I got the shaft free enough to clamp a mole wrench on and 'wiggle' it out. Not very scientific, but it worked for me - no guarantees though.
Good Luck
Good Luck
