Griffon2000
Olly49
Still trying a few combinations to get it right.
Started off with a 2212t6 2200kv with a 7x3.5 prop.....good power but high battery usage 3S 3000mah dedicated.
The video of the maiden, I ran a 2212t? 1000kv with a 3 bladed 6x4E pusher.......much better battery life although not much fwd speed but ok to learn its handling characteristics. I am sure that my attention span has dropped to goldfish level.
If you want to keep the traditional power pod look using a pusher prop then the first photo above is the go.
The power pod, fan cowling and rudders as a removable assembly and screwed down to the aft deck would be ideal.
Before fitting the aft deck epoxy 4 t-nuts (3mm) as the anchor points for the removable pod.
I have seen some 9inch assemblies and they she really quick and manoeuvrable.
Hope this helps.
Hope this helps.
