R.A.F Crash Tender
開始者 Mataroa
5 返信ies 0 いいねs 0 フォロワー 最終活動: 16年前
Hi thanks for interest in the San Diego. I'm looking for £250 plus carriage. it would have to be insured and I would pack as best as is possible but still would not guarantee the carriers handling off it. Brian
R.A.F Crash Tender
Regarding my speed controller it is a PROBE 12 0905 with forward and reverse. I am using a 7.2 volt nMh battery pack 3800 mA.
Regarding the guide for prop size - thanks for the information I will try it with a smaller prop at soon as the weather warms up. I've tried running the motor with the boat stationery in the garden pond, it didn't seem to get too warm (the goldfish did!) but I will take your advice and get a smaller prop, I wouldn't want the motor to fail in the middle of the water.
Ray
R.A.F Crash Tender
The general rule of thumb - certainly for direct drive - is not to use a prop whose diameter is larger than the motor case. A Speed 600 case is about 37mm diameter. A 70mm prop is WAY too big for a 600 motor. You'll just overheat it and then quickly burn it out. That model would be better using a 900 motor on 18v and a 55mm 2-blade prop.
Suit yourself.
DM
R.A.F Crash Tender
I also have a 48 inch RAF fire boat
I have fitted a Graupner 600 electric motor and a 70 mm 2 bladed prop.
I have not tried it on the water yet - waiting for the weather to Improve. Will post info once 'sea trials' have been done!
Raymondo
HI Raymondo what speed controller or you useing in the boat ?
is the motor 12v or 6v?
cliff 😊
Clifford Johnston
R.A.F Crash Tender
Raymondo
R.A.F Crash Tender
HI guys I have 46" R.A.F Crash Tender I was looking at motors for the R.A.F crash tender
I have few Ideas of what motors to use my self but I want to be suer about It so can any one tell me what Is the best electric motor ? for 46 R.A.F Crash Tender and what size propellor and speed controller 12v or 6v would like to make as realistic to the real thing
thanks cliff
Clifford Johnston
