Sea Queen Spray Rails
Yes some more recent models, predominantly made for racing do have moulded rails along the bottom.
Two reasons, one to add strength, especially if of thin material and secondly to provide lateral stability at the high speeds encountered.
When the Aerokits were designed in around 1960s plastic was not commonly available to hobbyists and models were designed using wood/plywood and the originals did not even have spray rails fitted. The running gear was also heavy and bulky resulting in much heavier models than are possible today so the hulls did not plane so easily and the rails were not needed for most models.
Technology can now turn out hulls in bulk using extruded and formed plastic and the rails add to the strength to help keep the shape. You can see this on most plastic packaging used for consumer items
