Voltage step down
開始者 misterbee
8 返信ies 3 いいねs 0 フォロワー 最終活動: 9年前
Voltage step down
Why not use the 12v battery if the ESC is Ok for 12v. Restrict the tx stick movement so that just 6v goes to the motor
Voltage step down
Just a thought-
The component shop does do a voltage reducer rated at 6 Amps power draw, and will drop from DC (10.5-40v to 1-9v) I thought about using one of these to run a 6v volt Marx Hectoperm motor from a 12v source, to save buying a new battery. As long as your motor speed controller setup doesn't draw more than say 4~4.5 Amps. I'm my case the tug had 4 x 6Ahr 6v batteries wired in parallel giving 16Ahr and 2-1/2 hours running time @full speed. These batteries have since all died due to age.
I wanted to use just 1 x 20Ahr 12v battery instead and keep the added ballast I need anyway. This 6 amp unit is on the limit in my application.
P.S i'm tight with money and I acquired the battery free from an alarm battery swap.
Voltage step down
Hi Brian, I would suggest 2 x 6volt NimH cell packs with a parallel 'Y' lead, the reason is you can use each pack to alter the trim of the hull. with a big hull like the Fire Boat, you could even put 4 x 6v cells in for longer duration. a single 12v does not give you a lot of maneuvering room regards balance etc.
I have just changed my 48" Fireboat to 3s lipo's from 7.2v NimH packs, this is with Graupner 700bb motors with twin 50mm 3 blade brass props, not tested yet due to poor weather and shift patterns, but it sounds great on the bench.
Etherow Model Boat Club
がいいねしました RNinMunich
Voltage step down
Battery ordered, and a charger, from Component Shop.
Thanks for the guidance.
Brian.
Voltage step down
Thanks, Dave,
That shows how little I know of these things,.....a 12 volt NiMh is obviously the way to go,
Thanks a lot.
Onward and upward!!
Voltage step down
Agreed Dave👍
A 10 cell NiMH would be my solution, or depending on type of boat; size, weight, performance demands, motor current etc possibly a 12V SLA or 2 x 6V SLA.
I use the latter very happily in my 140cm destroyer and 100cm submarine and can tap off 6V for various low current ancillary functions.
Will also do the same with my Graf Spee and Belfast refits - provides useful ballast as well 😉
Cheers Doug 😎
Voltage step down
Hi Brian
For your purpose I doubt if you can find a solution that will deliver enough amps for the motor.
You can buy 12v NiMh batteries which may be the easiest option if you do not want or require the performance provided by a LiPo which will only give you 11.1v (3s) or 14.8v (4s).
https://www.componentshop.co.uk/batteries/airsoft/108v-12v-packs.html.
If you do decide to change to LiPos I agree with Haverlock and you do need to read and research how to use and care for the battery.
がいいねしました RNinMunich
Voltage step down
What your asking for is possible but not easy. A 12V ESC will handle an overvoltage but I cannot say how much and depending upon the current draw of your motor a voltage regulator can be expensive. The simple solution is to get a 3s LIPO However you do need a special charger and have to make sure you do not discharge a LIPO to too lower voltage.
https://www.rchelicopterfun.com/rc-lipo-batteries.html
if your interested in going LIPO have a read about the care and feeding of them.
がいいねしました RNinMunich
Voltage step down
I know this will sound very basic to experienced members, but my question is; If I want to use an "MTroniks" Viper Marine ESC, which is rated at 12 volts, and a similarly rated brushed motor, how can I easily get 12 volts out of two 7.2 NiMh battery packs?
As you can surmise, my electronics expertise is zero.
Brian Hill.
