FRESH BATTERY RUNNING TIME
Hi Les, Sorry🤔 but this is another "How long is a piece of string?" question.
It's a simple equation to work out the theoretical endurance, but no input = no output!
Inputs required are-
Battery type and nominal capacity; mAh as printed on the battery pack,
Current drawn by all the electrics connected to it: RX, servos, sail winches etc, auxiliary motor if fitted. I'll leave that bit to the sailing buffs here. I have zilch yachting experience.
Re: depletion:
Battery should not be left connected when not in use!
You should have an ON/OFF switch in the boat to disconnect it.
If not in use for longer periods it should be removed from the boat and periodically charged, only to 50% capacity for a LiPo when stored. stored NiCads and NiMh should be periodically cycled; that means discharging to the safe minimum and then recharging SLOWLY. Good chargers have automatic programs for this.
Depletion, even when not connected to anything, depends on the battery type. A NiCad looses approx. 1% per month, NiMh and LiPos considerably less but still some depending on the internal resistance of the pack. Better quality (higher price) should mean lower internal resistance and less/slower natural depletion. Avoid cheapo 'no names'.
A pic of the battery would be more use than one of the RX😉
Cheers Doug 😎
