huntsman plan
開始者 big-tone
18 返信ies 20 いいねs 最終活動: 9年前
huntsman plan
Slippery things decimal points! 😉
がいいねしました ChrisF and Zdenek
huntsman plan
As Zdenek says, you can get a set of effectively any of the original Fairey boats form Charles Lawrence, there is a General Assembly drawing and a Hull Lines drawing. Some of the Hull Lines drawings have been prepared by Alan Burnett for modellers in the past.
They look to me like they are scans of original drawings to myself.
If people wonder why they are at 1 : 12 scale, simples the originals way back in the 1960's when some of them were drawn, in the days when we used 'real' measurements. They are 1 inch = 1 foot (2.54 mm = 304.8 mm)
huntsman plan
Yes, you can get a copy of the original drawings and model lines but you will still have to draw up all the bulkheads, keel etc. and decide on how you are going to construct the superstructure.
Fine if you can do it, but if you just want to get on with building it, get the plans already available.
huntsman plan
Tony, according to my latest "investigation", there is also a possibility of purchasing a modellers set of plans form The Fairey Owners’ Club. The plan is at a scale of 1:12 and it is a copy of the original Fairey drawings. Two sheets show the plan, long section and cross sections.
The contact is Charles Lawrence, email: czczcz@me.com
Zdenek
huntsman plan
Big Tone , opened up one of the kits , and surprised to find you were right , there isn't a drawing after all . Good luck with the project . Trevor.
huntsman plan
big-tone - even if the kits do have a plan, like most kits it will probably only have a top view and side elevation. There won't be any templates for the various parts.
If I was you I'd get a copy of the 31" version and scale it up. Being as they are drawings for scratch building they have all the information required and you aren't having to enlarge them that much.
がいいねしました Brucef102 and RNinMunich
huntsman plan
Hi Trevor I was told the kits only have a build manual no plan but if you have one for a 46 that would be great
.so far all I have found are plans for the smaller 31inch version.i can do copies at work if that would be easier I would pay postage do copy and return if you fin
d anything
Regards tony
がいいねしました SelwynWilliams
huntsman plan
I have 2 unmade Huntsman 46" kits ,and am sure there should be a plan in at least one of them . Will get a price to have the plan copied if you are still interred . Trevor.
huntsman plan
Hi Guys!
Both plans are available there: https://www.sarikhobbies.com/product/fairey-huntsman-mm680/ and there: https://www.sarikhobbies.com/product/fairey-huntsman-mm2111/
As far as the articles in MB 2016 are concerned, they were "just" a support for those who decide to buy the plan or an attraction for those interested in. As mentioned above, the article is very helpful.
I have decided to for a build as well, when I've read the articles. I had a chance to enlarge the original by 1,5, approximately. I did it because my intention was to use and modify a plastic hull I've had at home. it's dimensions were the scale factor... After some work I've realized the enormous extent of changes necesary and switched to a scratch build... Being very slow builder, it is still in progress, hull almost ready, waiting for the deck, spray rails and started the preparation of parts for the cabin.
がいいねしました AndyG009
huntsman plan
Big Tone - what you have sounds like a Huntsman built from the Precedent kit.
Plans are sometimes on EBay for the drawings for other kits but I've never seen any for the Precedent. But be wary of the EBay offerings - I've bought drawings and the templates have been very poorly traced/drawn and are almost useless and I've had to redraw them.
But as regards the Precedent I have one, bought already built and done pretty well so if you want any photos let me know.
がいいねしました suntugs
huntsman plan
Now you mention it, I might have got carried away there! I now think I must have sent off for the plans after reading the two articles. Apologies guys. (Sulks and shuffles off, head down).
がいいねしました suntugs
huntsman plan
You must be very lucky,
I have m/b 2016 right through but never saw a free plan will have to look again.
Hope its there 👍
Michael beck Wilkins McQuilkan
がいいねしました suntugs and Black Dog Jack and
huntsman plan
thanks for the info will take a look see if I can get the back issue. mine is a 46 inch refurb I picked on ebay going to strip back and bring back to former glory as its about 50 years old I was told
がいいねしました SelwynWilliams and Gravedigger47
huntsman plan
Model Boats magazine January 2016 ncluded a free plan of a Huntsman 31 complete with photos and a step by step build guide. Unfortunately the model is 24". I also wanted a bigger model so I redrew the plan double size. it wasn't too difficult and only took a couple of evenings with a some lining paper from B&Q and a calculator and voila! At the moment I am planking the roof of the cabins and trying to decide between a brushless motor and an old Weston rare earth brushed motor I used to use for fast electrics. The article in MB also ran into February 2016 where all the fiddly finishing bits were described, also with many photos.
I expect one can obtain back issues from their web site. Anyone interested in Huntsmen should get these two issues for the detail alone.
がいいねしました suntugs and Gravedigger47
huntsman plan
Thanks cannabis but that's the 28' version without back cabin mine is the 31'
がいいねしました SelwynWilliams and suntugs
huntsman plan
hi all looking for plan for the 46"fairey huntsman. I have been checking wed sites but cant find any.wondering if anyone has a set that I could copy or know if still available
thanks tony
