Best Tx systems for boats
Hi Sparkman
I have the Turnigy IA6 V2 with rpm, voltage and temperature sensors, great setup.
The throttle channel is setup for IC planes, so if you require central position for forward and reverse you require opposite .
Mode 1 IC throttle on the right is 9114000020-0.
Mode 2 IC throttle on the left is 9114000019-0.
The correct sensors are voltage 9114000013-0, temperature 9114000013-0 and optical rpm is 9114000026-0.
The ones shown on the transmitter page have the wrong connectors and require a special lead.
Canabus
PS the Flysky IA6 is the same unit, so you tube shows how to setup the sensors.
Canabus
