raf crash tender 3ft
開始者 georgeo5664
11 返信ies 5 いいねs 0 フォロワー 最終活動: 10年前
Paul will give you a call when I get it cause i need you to have a look at the position of the motor if you don't mind cause it seems to be too high
Hello Paul well the bent shaft is another purchase i managed to find a complete shaft on eBay which is the same dimensions as the boat so hoping when it arrives it will fit but overall length is 230mm and outside diameter of tube is 8mm 😆
George
Hi George, I'm stalking you!
So you have all the nice bits, what about your bent shaft!😆
Paul
がいいねしました georgeo5664
thank you all for your help i went on to Cornwall model boats and I couldn't find them but with help from vosper i have now ordered them and yes it is 1/16th scale i think i now have everything I need to complete it😆
がいいねしました vosper
I think that the 3 foot model is 1/16 scale
fitting kit has now been ordered and bits like the mast has been ordered from here but I am now short of the decal set would anyone no where to get them or the size of the letters needed appreciate the help fellow boaters
Your quite Welcomed, any time hope you find what your looking for. 👍
"Fair winds calm Seas"
73
thank you very much for your help i will be contacting them regarding what scale
hi would any one no where i can buy a full fitting kit for a 3ft crash tender any help would be appreciated
