Hull stand
開始者 paults
6 返信ies 2 いいねs 0 フォロワー 最終活動: 10年前
Hull stand
I mould a piece of thick solder wire around the shape I want then place it on the ply and draw round it with a pencil. Works every time and is re useable
Roger
Kent
がいいねしました stevethomas
Hull stand
This may be silly but if you push the hull into sand to get the shape of the hull, you could then lay a plastic bag or polythene in the hole made by the shape of the hull, you could then pour in some plaster Paris (not sure of the spelling !!) or a fibreglass liquid to make a mould which you could keep.
I know silly idea%uD83D%uDE0A%uD83D%uDE0A
Steve.
がいいねしました paults
Hull stand
Easy and cheep, us a cornflake type cardboard box, cut to the right shape with scissors then transfer to plywood to make the stand
Etherow Model Boat Club
Hull stand
Many thanks for the quick reply and tip. I have one of these that I had forgotten about. My hull is very large but I could do the section profile in stages using this tool.
Hull stand
There is a device that makes it simple
http://www.wilko.com/all-hand-tools/wilko-contour-gauge-5in/invt/0209036
one example there are others this allows you to copy the profile of your hull. This profile need not be a tight fit since its a good idea to have some form of padding ( draught excluder sponge strip etc. ) between the support and the hull to prevent scratching.
Hull stand
This might seem to be a simple question to some but can anyone tell me how to make a hull support stand for a fibreglass hull. I need to take a moulding of the hull at two stations, distance apart not critical in order to mark and cut out the two supports. I don't know what to use to determine the hull shape at these two stations.
