Ventilators
開始者 felix
11 返信ies 0 いいねs 0 フォロワー 最終活動: 11年前
Ventilators
oh as a possible inducement stainless steel silver solders just the same as brass and copper.
I have been told you can even silver solder cast iron but I have never tried.
Ventilators
Okay Haverlock
Thank you, will look into the information you have supplied on the silver solder
felix
Ventilators
Silver solder is a high temp solder and requires
red heat I recommend a gas torch.
its also quite expensive and requires different techniques and you HAVE to use a special flux.
if none of that has put you off laughs
http://www.cupalloys.co.uk/low-temp-silver-solder/index.asp
That's one source you need people who supply model engineers rather than a "normal" model supplier.
That's a how to guide
Ventilators
HI Haverlock
Thank you for the information on the silver solder, is it supplied by model shops
or is it a specialised supplier (s) that stock it I have always used standard solder
But can see the great benefits in using different temperature solders for the very reason you have mentioned, I am no stranger to that senario believe me, along with the odd swear word
With regards to polishing I used Brasso but found the fumes off it a bit harsh
and throat catching, I will try the "t" cut
Felix
Ventilators
At the risk of teaching to suck eggs etc.
When your working brass heating to red heat and quenching in water anneals.
Silver solder is available in different temperatures so you can build up structures in stages without the previous parts falling off.
ohhhh and "t" cut makes an excellent polish.
Ventilators
HI Haverlock,
Thank you for the information & suggestion I have now visited the site,
and see your point, I have decided to follow on with your suggestion, I will
work out a design on paper and purchase the materials required.
it is great to come on a site and find people ready to help, and obviously you
have given thought & time to my problem it was very much appreciated
Thank you
Felix
Ventilators
If you want actual working vents why not fabricate "mushroom" vents from brass tube and sheet?
Full sized examples here
http://www.chandleryworld.co.uk/catalogue/brass-mushroom-vents_c2303-2.html
as a fabricated item its not a difficult build. Brass tube and sheet are available from a LOT of model supply sites.
Ventilators
HI Haverlock,
"My enquiries have fallen on stoney ground",
I am thinking of making the ventilators myself
as I only require two (2) to assist venting the motor compartment
Your Guidance was not all unfruitful it was interesting, going through the items
that are available, in fact I have taken a note of the site for my next project
Thank you
felix
Ventilators
I posted those websites as examples please don't take it as graven in stone that they are the only ones supplying this kind of material.
Ventilators
HI Haverlock
Thank you for the reply, I have tried numerous suppliers /sites over the last
three weeks, but none in the direction you have given me,
To answer your question why brass the project is a model 30s steam launch which
I have converted to electric power, with a dummy boiler and steam engine compartment which houses the motor.
All fittings are brass and exposed timber is varnished
Once again thank you for your guidance, and I will check these sites out
Felix
Ventilators
To say no one makes them would have a flood of replies proving me wrong BUT I think your going to have a lot of trouble finding some.
You may contact
http://www.model-steam-boats.co.uk/index.html
The do very high class fittings in brass.
Failing that why brass are you not going to paint them?
if all else fails you could manufacture your own in copper using metal clay
http://www.kernowcraft.com/jewellery-making-tips/jewellery-making-techniques-product-advice/working-with-art-clay-copper
Another possibility is to use cold casting techniques
http://www.aldaxstore.com.au/
Hope that gives you some ideas
Ventilators
Hi,
I joined the form recently, this is my first post I am working on a project for my
grandsons, for which I am looking for two brass horn type ventilators the scale is
approx. 1/12
I have searched all the various model suppliers, but plastic seams to be the norm
has anyone any ideas of a possible supplier I would be grateful of any suggestions
thank you
Felix
The Problem is now resolved thanks to a suggestion, guidance & time from Havelock
Felix
