@ChrisF .
The difference is in the name.
An Abrafile is basically a completely round fine file, and this is why it is able to cut (or file) equally well in any direction.
This construction gives a very fine clean cut - valued by jewellers and anyone that needs or wants to cut very fine detail in an enclosed space.
Abrafiles can be particularly helpful when working in tight spaces or totally enclosed spaces that needs the file to be inserted through a drill hole before being re-connected to the saw frame……not unlike cutting a window aperture with a scroll saw.
I have “hand-held” an Abrafile when I needed to make a small cut-out and it did work, but a suitably shaped Swiss file would have probably been as good or better as the Abrafile works best when under tension in a saw frame.
I have yet to test the spiral wound saw blade construction of the spiral fret saw, but I can imagine that can take a much bigger cut but may not be quite so suitable for very fine work?
Soon I will be able to test them both and hope that I can use the spiral wound blades to cut as well in every direction as the Abrafile, but I am not expecting to be able to achieve as fine a cut or for it to work as well with thin materials or fine metals .
Both blades have their uses, but sadly Abrafiles are not generally available any more, and I am not even sure if they are manufactured any more?
