Did I post this early?
It was sailing this past Sunday at our meet. A RTR heavy plastic Brooklyn Tug. Not much for ballast and certainly not scale running as can be seen in this video.
It also spayed water at the kids.
がいいねしました USA Corsair and EdW and
@Ronald couldn’t find the 2 pieces for the rudder assembly for the fiberglass hull. So I just used the pieces for the plastic hull and incorporated them to the fiberglass hull. The deck is built next step is planking. Stuffing box is installed. At the present moment I’m working on 2 boats. The other is Dumas Donzi sport fish. Time is definitely not on my side trying to find it to work on either one.
がいいねしました hermank
Hi Ron! Due to a series of unrelated work and home repair issues I've not been on the tug boat for a bit. Now that I am away on vacation i've delayed it even further. However, just before leaving on vacay; I started weathering the superstructure and wheel house and am retrofitting (trimming down) the original drive system to fit into the newer Dumas 2-piece model hull. I am also trying to figure out the best electronics combo to marry to the original Dumas 12V motor with speed control etc. So, when I get back I'll jump back in with both feet.
Many thanks Dave!
It always helps me to be curious with things like this in order to stay on a budget. Especially these days! Everything posted on these pages has and will always be a help to me. And in this case I too am wondering about going with the original Dumas offset geared set up. I have built the drive system, but not fully committed to it yet.
がいいねしました hermank and AlessandroSPQR
Guy,
It is an older build. I didn't build it; I acquired it from a club member who needed to downsize.
I'll attach some pics from the inside of the boat for your reference.
がいいねしました USA Corsair and AlessandroSPQR and
@DWBrinkman
Dave!!!
Please let me know your mode of power and electronics used on your tug!
Many thanks!!!
— Guy
Dave!!!
Many thanks!!!
— Guy
がいいねしました AlessandroSPQR and hermank
I don't know if this is any help or not.
I took a couple pics of mine.
If I can do anything else, let me know.
PS I don't have the plans for the boat.
がいいねしました AlessandroSPQR and EdW and
I can only provide half of your request, but you're welcome to it.
がいいねしました chugalone100 and hermank and
Hi Ronald & puttn,
Ed Figuero's Brooklyn Blog immediately sprang to mind with me as well.
Link to the Blog below.
I don't think he ever launched it😒
All we got was a string of 'reasons' why not, then he had considerable family problems and he kinda disappeared.
https://model-boats.com/blogs/38209
I recalled that Ed Figueroa ( figtree7nts) did a long series of posts on his building of the Dumas Brooklyn Tug. I have reached out to him since it’s been 7 years now since he began his building blog on this website. We were all waiting for photos of the launch but I am not sure it ever happened. Let’s hope he kept the plan sheet and will be able to assist you with the missing details for your rudder assembly.
@Ronald
Sorry I missed you last night Ron! Thanks for the message!
I was driving my daughter back to her apartment in NYC. Dark and wet drives to NYC are
always a serious pain-in-the-ass. By the time I got home I was dog tired.
がいいねしました hermank and premecekcz
@jumpugly
Agreed, thanks for giving your suggestions.
Regarding putting small screws into the fibreglass hull, if he applied epoxy to the area first and filled it about 1/4” or more, before drilling the pilot holes fore the screws, he should be fine.
がいいねしました hermank and premecekcz and
Puttn: finding these parts would be almost impossible. Although a decent set of plans from the older versions would be the way to go in order to fabricate a set. In this case I might just go with the modern plan template for the brass keel extension. If you don’t want to drill into the fiberglass hull for the screws, I would then fiberglass the brass keel extension directly to the hull.
Be that as it may and considering the photo you have of the parts I would start hitting the building blogs to see if any of those builders might have some leads towards the actual shape and dimensions.
One thing I would definitely do is post your photo on the Facebook “Radio Controlled Tug Boats Only” page and let that gang know what you are looking for.
がいいねしました AlessandroSPQR and RodC and
@Ronald I probably could make those 2 piece’s if I had the measurements. Unfortunately I do not.
がいいねしました hermank and RNinMunich
@Ronald yes I’m pretty sure they’re metal. I have everything for the rudder assembly for the 2 piece hull. But did not realize the 1 piece fiberglass hull is different for the rudder mounting. I’m thinking I could use the set up for the 2 piece hull. But would rather have those 2 pieces. We shall see. Thanks
@puttn
Those are very unique to that particular style of tugboat. Never having built one of these Dumas tugs, would these be White Metal castings?
I could imagine they are white metal casting which with some careful fabricating, you could duplicate them using brass bar, brass rod and brass tubing?
がいいねしました stevedownunder and RodC and
Dumas Brooklyn Tug
Looking for some help. In search of the 2 piece rudder post for the 1 piece hull. The upper and lower rudder post. Any help would be appreciated. Thanks
がいいねしました stevedownunder and chugalone100 and
がいいねしました
読み込み中…
