Ronald I reckon it's the best type of photography using sheet film sized anywhere between 5x4 " and 10x8 "
@Chum444 The trick only works for small portholes where surface tension holds the resin in place. If the drop of resin is small there is very little bulging. You can correct this in the larger sizes by letting the resin half-set with the portholes facing down, then inverting them so that gravity pulls the outside face nearly flat. Any bulge on the internal side of the porthole can simply be filed down, of course, if you want to. I found that doing this trick with the hull of the Revell Flower class Corvette resulted in a sort of magnifying glass bulge which concentrated the internal lighting very well...
@DodgyGeezer Good idea. How do you make the exterior surface flat?
I have used various types of clear plastic to make my windows. The clear plastic containers found in your grocery store that contain any multitude of products from produce to bakery items.
The clear plastic of an envelope window is light weight.
The page protectors used in documents and binders works well too.
がいいねしました
読み込み中…
