Transmitter brake down
Thanks for the post I had not seen this option before. The twin throttle we use only replaces the gimbal so it is just plug and play. Attached is a copy of an article I wrote for Task Force 72 about 10 years ago, hope it explains the conversion better. But to summarise you remove and dissemble the original gimbal, use the pots and reassemble using the printed parts as well as a small compression spring and "T" brass wire parts. My original twin stick radio is still going strong.
Hope it helps
Hope it helps
