1990 era Traxxas XL-1 electronic speed controller
The first of the RC tx's just turned the 27Mhtz carrier wave on and off, there was no modulation as that required a stable carrier frequency. My Fleet 4 Ch pre-proportional set had a blue crystal soldered in place to stabilise the oscillations. That was the first time I ever saw a crystal in use.
That would be around 50 years ago now.
In those days a servo was an electric motor powered escapement. I had a rudder servo that drove a screwed rod with a travelling 'nut' which was for the rudder movement. This needed 2 switch controls one left and one right, the rudder would move end points and then the end microswitch would cut the current and when you released the Tx switch it would centralise the rudder again. Very sophisticated!
Back then for speed which was from dry batteries I had a sequenced pair of relays that would run the batteries in either parallel or series with stop in between. Still got them!
I never did use i/c always electric.
がいいねしました premecekcz and hermank
