two or one
A couple of days ago "Chugalone100" asked, "In a twin-motor arrangement, is a throttle mixer required to properly coordinate differential thrust control, or can this be managed directly through transmitter programming?"
For many years the connection between the radio receiver and the servo, or motor controller has had three wires, these are conventionally coloured black for the 0 volts line, red for the nominally 5v line and white for the pulse.
This is the way my torpedo boat destroyer is configured. The white wires for the two 'up-down' sticks are connected to a single pole double throw microswitch, one channel to the normally closed contact and the other to the normally open contact. The common is connected to the starboard motor controller, the left stick is also connected to the port motor controller. A servo connected to any other channel operates the microswitch. So in one position of the microswitch the motor controls are connected and both motors are controlled by the left stick. In the other servo position the two motors operate independently. The rudder is operated conventionally by the right stick left-right. The two extra proportional channels on my FlySky FS-I6 rotate the forward gun and the torpedo tubes.
My USS Melvin (Lindberg kit) has a different system. Up-down on the left stick controls the power to both motors, left-right on the left stick controls the balance between them. So I stop both motors and put the stick over one motor will run ahead and the other astern. The motor control is a home designed and home built job. I built the USS Melvin in 1979 when I was home on leave from the British Merchant Navy. Since the only fault has been a failure of one power transistor.
I normally run the USS Melvin on my 4 channel Futaba transmitter but sometimes on either of my 6 channel Futaba transmitters.
There are other ways of doing it.
がいいねしました RNinMunich
