Model slipway 1/16 RNLI Tamar Lifeboat
開始者 lukeH
16 返信ies 41 いいねs 最終活動: 10 ヶ月前
#17 3
I guess since this is a lifeboat going out to make a rescue, the old song, “What do you do with a drunken sailor”
makes a good application, he won’t be able to tell you anything about the reds and greens. He is just be glad you are there to rescue him.🤪😘🤢🧜🏽‍♂️
がいいねしました DWBrinkman and hermank and
#16 3
Hi Hermank, my friend, don't worry, you're forgiven, but don't ever do it again, hahahaha.
The fact is, many of us here are familiar with Colreg, Iala, and many other international regulations, and on top of that, there's also AI, which, with the question of the day, is training us and creating infallible war machines, hahahaha.
がいいねしました lukeH and hermank
#15 3
Many years ago the model on the front cover of the Model Boats magazine had the feature article model image reversed. I expect the graphics designer thought the photo looked better that way round.
Having written that I think I used to know the graphics designer, but more into soldiers, he was a very nice guy, but there you are!
がいいねしました lukeH and Ronald and
#14 3
Ronald
thank you for your remark. The model has been on an exposition and nobody made a comment!
unforgivable
The leds are 3 mm
がいいねしました Ronald and AlessandroSPQR
#13 3
gentlemen skippers
being a model yachtbuilder for over 6o years and a sailor for over 20 years what an horrible mistake i made!!!!!! i can't forgive myself.
I m sorry, i m sorry i m sorry
がいいねしました roycv and Ronald and
#12 3
Hi Hermank, congratulations, you did a great job.
I also think the green light should be moved; the red light should be on the left.
For the switch, I suggest using radio-controlled ones instead of manual ones if you have the radio channel available.
がいいねしました Ronald and hermank
#10 3
Herman
Red is on the Port / Left side of vessel.
You have your navigation lights reversed.
What size LED diode are you using?
がいいねしました chugalone100 and AlessandroSPQR
#9 3
Hi Luke you're idea regarding lighting is possible. I have mine linked to an electronic switch and a fob that i have attached to house keys. It allows me to have the lights completely separate from the receiver and is powered by a small 2s li-ion. It means i can independently control 4 light functions, though one channel can easily be a radar or smoke machine etc. For flashing i'd opt for a simple flasher unit.
I'd normally opt to wire all the static lights together then blinker seperate. For smoke unit or radar i'll fit an inline fuse. With the 2s battery it's enough for a weeks worth of sailing.
Best wishes
Scott
Scott (Haggis)
Scotland
がいいねしました hermank and DuncanP and
#7 3
Thank you Hermank! Very much appreciated 👍kindest regards Luke
がいいねしました AlessandroSPQR
#5 3
Luke H
You can order micro motors at ali express without reduction, much smaller and doing 45 r/ minute on 6v
Hope this helps
がいいねしました AlessandroSPQR and lukeH
#4 3
Luke H
As you can see i m a lifeboatlover i do have 4 and number 5 is on the wharf. The Tamar 1/12 from speedline as i als made the Trent 1/16. Hereby some pictures of the actual status.?if you fo have any questions don’t hesitate to text me
Enjoy the building
がいいねしました AlessandroSPQR and EdW and
#3 3
Hi Thank you for the reply and that's very kind of you regarding the nav lights..thank you again!
Im thinking red port, green starboard and 2 white..1 for mast headlight and another for the sternlight, maybe an interior red light for the wheelhouse, a flashing blue light if its possible without flasher units etc?
as I have no clue on how they work or how to wire them to the reciever?!
Im hoping to keep it simple and wire all the lights and radar together and run it off a 12v battery box with a switch located somewhere in the wheelhouse as not to interfere with lifting the wheelhouse off to reach the rc equipment in the hull..again not sure if that's possible yet? But if you have any ideas on wiring etc that would be a great help!
The radar is perfect im thinking! so thank you again..I'll trawl the Internet when ready for that section of the build!
Thank-you again and kindest regards Luke 👍
がいいねしました AlessandroSPQR and HappyHaggis
#2 3
Hi Luke
Lovely choice 👌. One of our ex club members had one and it's a stunning vessel. As for the outfitting I can't help there though with radar and lights certainly can. Let me know what colour of led lights you need as ive thousands of diodes here in every colour and will solder 25cm of cable on and get them to you. For the tiniest of cost they owe me they are a gift to you.
In regards to the working radar have a look at the photo I include. They are built rather well and the 30rpm version looks most realistic. Can alter that speed more by connecting it up to a 1-5amp brushed esc and running it off a pot on the transmitter
Scott (Haggis)
Scotland
がいいねしました jumpugly and DuncanP and
#1 3
Hi all, I'm hope everyone is well!
Ive just ordered a MS 1/16 RNLI Tamar lifeboat and was hoping to reach out and ask if anyone has some build pictures or their boat project they dont mind posting on the site 👍
I have a few ideas on what r/c gear i want to install along with a working bow thruster 😁
Im after some Inspiration on working radar, maybe 1 interior wheelhouse light along with navigation and mast lights👍
The finer details around the wheelhouse and deck i think ive pretty much thought it out🤔but any ideas or some pictures of your builds would be very much appreciated if you dont mind 🤞
Many thanks for your help and time and Warmest regards
Luke
がいいねしました jumpugly and hermank
