8 Channel Transmitter
I'll cast another vote for the flysky i6x, for the price it's really hard to beat. There are 2 ways to adjust for throttle centring. The obvious way is to actually install a spring, which takes a few minutes and requires disassembling the radio and not letting the tiny spring fly away (serrated tweezers really help)
The other way is to use the throttle curve function, map it to a switch and set UP to 50-100 and DOWN to 50-0. I think of this like the gas pedal and gearshift in an automatic car. Throttle stick down is zero, up is full and the switch determines direction. This could work if one still wanted to use the transmitter for aircraft as well
Radiomaster is my go-to at the moment, very powerful for the price but the learning curve for edgetx/opentx is a cliff. The newer radios have an externally accessible grubscrew to adjust the ginbal springs. My Tx16s mk1 didn't have that so it got a new gimbal from a mk2 so I can switch between boats/trucks and aircraft with a 1.5mm hex
がいいねしました LewZ and Northernflotsam
