Need help identifying
Brass should only be used if the boiler is low pressure, less than 30psi, and less than 3” in diameter. The brass will degrade over time. The best material for small boilers is copper a with silver soldered joints. Larger boilers that are structural, as in traction engines are normally steel.
Tried to find my book on boiler rules but cannot find it at the moment.
Ed
がいいねしました hermank
