why does my motor only go forward
開始者 Redpopman
8 返信ies 29 いいねs 最終活動: 2年前
"Not sure why I asked that question because everything is on eBay or Amazon 🤣 "
Right you are Red.
Here you go😉
Doug😎
https://www.ebay.co.uk/itm/334633950923?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D282516%2C282613%2C282679%2C282209%2C282600%26meid%3Dc790072d22a84f27b77572f90d918a62%26pid%3D101875%26rk%3D3%26rkt%3D4%26sd%3D226101805881%26itm%3D334633950923%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DSimVIDwebV3WithCPCExpansionEmbeddingSearchQuerySemanticBroadMatchSingularityRecall%26brand%3DHobbywing&_trksid=p2332490.c101875.m1851&itmprp=cksum%3A334633950923c790072d22a84f27b77572f90d918a62%7Cenc%3AAQAKAAABQOqalcCsb07ituDYLOrUrH2eG1DBUcAU1siB%252B881ennut1KqikNJ--C2JmJJYbnGBSq9s1cAaLR3u1P2GFHP6cOkMtiQrPwhnArZTi0NFnCkYNs9wPMPnRY0lLYAH0ZUZFEi1Wo0j96MrvjkmH8m1XIZ%252BONhFtay47%252FZiydsQgndwvXa%252B4O3sxEFfzSWywNdmgQotiO8VMPBn3%252F7zxmcXEWYqTQQ33t48VGiixc%252Fe8lUGSZDh9C0eyKxSdeiAW2Xpve8axkA2xMbgjcWC3He4p42bvyDmMEQT1lbKLzFxg74TRYnUQ0OS7l6SuGoL9bOOf%252FEYqvF7tptjHJBp23Qx%252FzwD1uVIHwkcUsnbUCpMzwW7lW3EOJrHFieM9lxYu8SaduLIKGPOn4IYBeFvDTbPjrWYOaLdSo%252FKRashmAhtNCE%7Campid%3APL_CLK%7Cclp%3A2332490&epid=844395327&itmmeta=01JQ7ZPV7SRADYA64CEVJV2YD3
https://www.ebay.co.uk/itm/226101805881?_skw=Hobbywing+16bl30+program+card&epid=844395327&itmmeta=01JQ7ZJ5EFXQBEM7RFMF4ZTWJR&hash=item34a4b7c339:g:LKsAAOSwhXlmIqgi&itmprp=enc%3AAQAKAAABAFkggFvd1GGDu0w3yXCmi1cCSfgvTOH0M1Lwd7K4Pd3Ea4mH0OS3zkyZzCO4NeEXNu9AmvMLLg1Z%2BhXGm9OaDDgufYOhOfCbGkbM3VdT6XirlkJkC4Djx%2FAFytQfPGHqDGTYCPnEz4fcKs20qObAijmMrWEnEl%2F%2BhSKiOLKB1v5JTR0UpWX65H0sj2xdjoK31N22%2Blge9HCLAHM5gZFgJAnzwjO0o2%2BkieM5LGsQBrziSy4gppgyB4DQuaHry3Nbp7I8UbdlRfTv%2FytVyIoRtjZ8BNy0uND79xkxGZc3n0RekUbRN6IGOr5ELvn38FyGADSmGFw6uvlq5t148dAeLOQ%3D%7Ctkp%3ABk9SR67XyP-5ZQ
がいいねしました hermank
I got my program card from Wheelspin Models.
The Quicrun and Seaking are my go to ESCs.
がいいねしました hermank and RNinMunich
thanks Doug, managed to download the PDF and followed the somewhat overly complicated instructions to program the reverse all sorted now thanks again. where can I get the Quicrun program card from ?
Red Budd
がいいねしました RodC and jumpugly and
I'll second the 16BL30, as it's a fine esc. You CAN program it without the program card using the set button, but that's almost as bad as the "happy transmitter dance" we were subjected to about 15 or so years ago.😮
がいいねしました RodC and hermank and
Hi Herman.
I don't have the problem. Redpopman does.
I have already recommended that he buys the Quicrun Programming card (which I have), and which I assume is what you meant by 'Black box'.
がいいねしました RodC and Redpopman and
RN Munich
Do you have the black box that quicrun is selling? This is to me the key to your problem because with this boc you can arrange/ change all the parameters
I hope this explanation helps to solve your problem
Hi Red,
Attached 16BL30 manual -
See section 05 Programmable items.
Download to your device to read properly.
Small down arrow in top left of window.
No Red you most definitely have not!
The 16BL30 is my 'stock' ESC for brushless and your set up is almost identical to mine in my Sea Scout, 16BL30 and a Propdrive 2830 1000kV motor.
2 possible solutions-
1) The ESC can be programmed for 3 modes, including forward only.
The other two are-
Forward- Brake- Reverse. Which is irritating to say the least😠
Forward-Reverse. Which is what you want for marine use. Option 3 in the programming.
Check your manual for programming. I thoroughly recommend that you buy the Quicrun programming card, much easier than counting the beeps🤔
2) If your TX is one of those designed for the 'Fly boys' it may start in Forward only mode, and during switch on you may have to pull the throttle stick full back to initiate reverse capability.
If you get stuck give me a YELL and I'll post the relevant manual section and how I set up my Sea Scout. I use it with a Turnigy cloned (Badge engineered in Germany🙄) i6 TX.
What are you using?
Bon chance mon ami🤞
PS Swapping any two wires to the motor will only change the direction of rotation.
It has no bearing whatsoever on the ESC mode of operation.
I have a Hobbywing QUICRUN WP-16BL30 BL ESC and a brushless D2830-11 motor but it only goes forward - why can't I get it to reverse I've swapped the wire round in all combinations with no change. Have I bought a forward only ESC ?
Red Budd
