Complete newbie help please!!!!!
HI Jeff
Just had a further look at the VIPER 15 specs on the Mtronik web site.
They mention that some 2.4Ghz sets are designed for aero use and have a failsafe setting on the motor channel relating to full down on the throttle stick. it's possible that the Fwd/rev setting on the Tx also need changing the original setting would have adjusted to the settings on the 40Mhz set.
You should be able to reset this but you will need the instruction manual for your TX. A quick work round would be to use another control stick on the TX and the appropriate receiver channel ( use the rudder servo to identify the correct Rx channel) and see if the problem resolves.
Hope this helps.
Hope this helps.
がいいねしました acoustic49
