Painting a Fibre Glass hull
I agree with Greg's preparation system. The abrasion is vital to get good paint adhesion, even if it hurts to loose that lovely gloss gelcoat finish. It is then important to use the correct primer for whatever finishing coat you will use as not all paint systems are compatible.
In the past I have used automotive primers with no problems and recently I have been trying Multi Surface primer from the DIY store, with acrylic topcoat and water based Polyurethane varnish finishing coat - so far so good!
