Aerokits pt boat bulkhead plans wanted
I assume he has via Mahem as someone with a different name asked for exactly the same which would be too much of a coincidence.
Maybe he will update us on here, if that is the case, but after only 2 posts over 14 years, both asking for plans, I'm not holding my breath! 🤔
がいいねしました Len1
I am pleased that you may have found what you are after. My reason for asking was because I don't have any way of making a PDF, but I have drawn out on carboard the bulkheads of the RAF Crash Tender. I could have sent you these in the post if you couldn't get anything else if these would have helped you.
BOATSHED
がいいねしました AlessandroSPQR and Len1
I did CAD drawings for an 1/24 Elco 80' hull many years ago using the line drawings provided by John Lambert and Al Ross from their book Allied Coastal Forces of World War II (awesome source for building MTB's) as a reference.
John Drain's site at pt-boat.com is also is a great reference, and he might be able to provide you with a PDF of the hull section lines I got from Allied Coastal Forces, so you can project the bulkheads and the transom for the Aerokits Plan and Elevation drawings.
Aerokits didn't tend to include bulkheads in their plans unfortunately.
You may be lucky and find someone who has built one from scratch in the past, drew the bulkheads out and kept the drawings, otherwise, you'll have to draw them out yourself.
Will
Will
がいいねしました Len1
がいいねしました
読み込み中…
