Krick "Paula IV". On how to glue the Hull to the Deck ABS.
Hi. mek is very good you will not beat a weld for the strongest joint .it depends how wet your join is, on curing time anything from 2 seconds to15 seconds but remember mek can distaut plastics test on some scrap abs first. I repaired a split hull and deck made it strong and good as new take care hope this helps peter l 👍👍
がいいねしました Len1
