Thank you all. I went to my local hobby store in my area and asked the same question. They suggested using Maxi-cure extra thick along with Insta set.
here is the info on this. I am trying this product now and will let you know what I found out.
Thank you for your input
Maxi-Cure™ extra thick CA is the best CA for most plastics, including GE’s Lexan MAXI-CURE™ is the best choice for plastic model assembly. When used with INSTA-SET™, it works better than any putty for modifying or filling voids. It can be carved with a knife or razor blade and sanded and feathered to form a finish indistinguishable from plastic. MAXI-CURE™ bonds fiberglass, hardwood, metal and rubber better than any other hobby adhesive. For gluing to the inside, clothtextured surface of fiberglass, scrape the area to be bonded with a razor blade or coarse sandpaper before using MAXI-CURE™ or any other adhesive. It also is best for bonding the tires for R/C cars.
MAXI-CURE™ has proven to be very popular in the archery business for the fletching of vanes onto aluminum and carbon arrow shafts. Along with being the strongest, MAXI-CURE™ is usually the least expensive option for this application.
See this product's reviews on Amazon
https://bsi-inc.com/hobby/maxi_cure.html
