Rustoleum Pain Can Nozzle Restoration
Back in the 'old days' these were the tool of choice to painters everywhere.. (for kerosene blow lamps) the wire is just small and stiff enough to tease the clog cr?p from a paint can nozzle!
May4th be with you!
がいいねしました Captainnick and Colin H
Good tips - and I like Colins idea of saving old nozzles after the cans are empty! (something I have done many times over the years!).
I sometimes drop the dirty rattle can nozzle into a small screw top jar (like an airbrush storage paint jar) part filled with thinners - and give it a good shake .
This agitates the clogged paint (after it has had time to soak) and can save risking any damage to the nozzle if you don't have the correct size drill bits to open them out accurately.
Soak - Shake - Repeat. This process can be repeated several times until the nozzle is clear and doing more than one nozzle at a time (if your jar is big enough) helps the agitation and can save time if you have more than one blocked nozzle.
がいいねしました Captainnick and Colin H and
When I use Rattle cans and I have finished spraying I turn the can upside down and continue to spray into the booth until the spray is clear. Have not had much trouble with the nozzle clogging since doing this.
You probably do this anyway.
That's a helpful tip Lew.
Whenever I use rattle cans I re.ove the Nozzle after each use a put in a jar of cellulose thinners till next needed, then blow through with airline before use. I even keep nozzles from empty cans the same way so always have a few spares.
This happened to me several times so I thought I would pass this tip on to you all...
Lazy, forgetful, or it just happens, I get some of my "rattle cans", in particular here Rustoleum brands where the little plastic nozzle gets clogged. So, here is what I do to clear the clog:
☹️Pull the nozzle up off the can.
🤣Soak overnight in paint thinner.
🤓Use a .125 inch diameter drill bit to clean out the paint on the inside (do not drill through).
🤓Use a .030 inch diameter drill to clean out the nozzle hole to center hole. (do not drill through).
🤓You might need to repeat drilling steps several times.
😮Blow out any particles.
😉Replace nozzle (not to hard to avoid accidental spray).
😊After this I have not noticed any difference in the spray pattern - works great.
Florida 🌩️☹️ today, USA
がいいねしました flaxbybuck and DuncanP and
がいいねしました
読み込み中…
